2nd Gen R56 Cooper S What is the Best Bang for the Buck Mini Mod
Discussion in '2nd Generation: 2007+ R55 through R61' started by AXO, Dec 27, 2010.
  1. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    And a couple track days before then I'd wager! :ihih:
  2. minimark
    This ^
  3. minimark
    ....and this. ^
  4. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    OK now I am convinced on focusing on my suspension. :Thumbsup: :Thumbsup: I will get the 22mm rear sway bar, I may even attempt to install it myself. Now some New question? Are all rear sway bars deemed equal. I really dont have a color preference :lol:. I do have the Sport Suspension option. I think my rear sway bar is 19mm. I guess I will upgrade to a 22mm. I dont think I need an adjustable one. Which one do you guys recommend?
    Thanks for your help and guidance! :Thumbsup:
  5. minimark
    H-sport.
    Call Helix!
  6. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    The only thing lacking is sufficient negative camber up front; IE fixed camber plates will fix that. I would put IE fixed plates at the top of the list next to practice, practice, practice. Wear out current tires and have fun doing it, then try non-run-flat performance tires.
    Your rear bar is 18mm RealOEM.com * BMW R56 Cooper S Stabilizer, rear, it's adequate for the time being. Once you are at a point you understand how to use that tool, choose a bar with Teflon impregnated rubber bushings.
  7. kimberlein
    kimberlein New Member
    Jan 1, 2010
    33
    Bellaire, TX
    I'd do at least one track day before you tint your windows... if you like the track, you might want to wait on the tinting or at least get a lighter tint than you might have started with. On the track, you want to be able to see really really well out of ALL your windows (on both sunny and cloudy days). And as you get into better run groups, you'll probably want to be able to communicate to drivers behind you by tapping on your rearview mirror (so they'll need to be able to see your rearview mirror through your back window).
  8. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    These are all good things to know. I guess I will hold off on the Tint, It makes sense..
    I hear a lot of people raving about camber plates. I have no clue about how these should be set. You mentioned Fixed, so I assume they are installed and not adjusted.
  9. minimark
    Camber plates are great but for someone starting out lack the easy adjustability of the adjustable rear sway bar. Being able to adjust in and out a bit of under steer helps you to understand what's going on when changes are made. Then as your driving progresses the very next thing would be camber plates. Just my 2 cents as there is always more than one way to skin a cat. :)
    ...and yes fixed means that you will have a preset camber with no way to adjust. Then there are adjustable camber plates that allow you to dial in the amount of camber desired such as the Vorshlag Camber Plates. These adjustments require a realignment.
  10. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Great advise with one caveat, I think. Is it not true that with fixed camber plates you cannot use either better quality springs or coilovers? You basically stick with the OEM springs
  11. BThayer23
    Not true. Fixed camber plates are compatible with any stock-diameter springs, aka lowering springs. Coilovers are a different animal, and you wouldn't pair fixed camber plates with coilovers.
  12. minimark
    Ben is correct, I've run both the fixed and adjustable plates with TSW springs.
  13. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Thanks for setting me straight Ben, appreciated
  14. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    If I understand this clearly. I wont need a 4 corner alignment with the installation of fixed camber plates and a 22mm rear sway bar? :confused:
  15. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    You will need an alignment. Adding camber (or taking away really) you mess with the toe, and it WILL need to be corrected. Also, when lowering the rear-subframe to do the sway bar, you will have likely "tweaked" the rear toe as well.
    ^^ From personal experience.
  16. BThayer23
    It's actually a smart idea to do those two things at the same time - that'll save you some $$ from having to get an alignment twice.
  17. Justa Jim
    I did not realize you needed an alinement when you add a new sway bar. That could change my plans a bit. Bummer.
  18. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    #38 AXO, Dec 29, 2010
    It definitely makes sense to do both at the same time. I haven't priced a 4 wheel alignment yet.
  19. minimark
    A good alignment should include all four wheels. Also I've never had to do a realignment when only a rear sway bar is installed, it doesn't change the alignment settings or the attitude/geometry of the rear suspension other than the resistance of the sway bar itself... 2 cents
  20. Metalman
    So the rear subframe that you need to drop in order to change out the rear swaybar isn't going to affect the alignment if it moves out of place? Are there locating pins that maintain the subframe's position?
