1st Gen R53 Cooper S What is your suspension setup?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by panaphobic, Aug 11, 2010.
  1. drabdub
    drabdub Well-Known Member
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    im loving the audi rims on the mini.
  2. agranger
    #22 agranger, Aug 16, 2010
    I've got a 2006 MCS that came with the sport package.
    Jango is an all-around car. I like a lower, agressive stance, but I also live in a metro area with lots of pot-holes and speed bumps. It is part daily driver, part show car and part track toy.
    My current suspension setup:
    1. Stock struts
    2. TSW springs (I've got the beta version of the rear springs, so they are a bit lower than the springs that are currently sold... they added about 1cm of ride height to the spring specs after they saw how my car settled). The front height of the production TSW springs (now Way Motorworks springs) is the same as my car.
    3. 21mm hollow rear swaybar
    4. Ireland Engineering fixed front camber plates
    5. Adjustable rear lower control arms (went to -3 degrees of camber without them... car looked like this from behind: /--------\
    6. Powerflex LCA bushings and rear trailing arm stiffeners
    7. A UMP lower front brace, M7 upper front tower brace and a upper rear tower brace.
    There are lots of pics in my garage, including one in the suspension section that I photoshopped one pic on top of the other, to show the before and after look of the stock springs vs. TSW Springs.
    In a year or so, when my stock struts wear out (at 58k miles now), I'll probably put on a set of coilovers... I'm thinking of the TSW KW Variant 2 setup (KW Variant 2 Coilovers R50,52,53 - Way Motor Works)
  3. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Let's see...
    I've got
    Hotchkiss Adjustable Camber plates
    H-Sport Lower Rear control Arms
    R56 Al rear Trailing arms
    Leda single adjustable coil-overs
    Currently running ~325 in/lb springs, but will go back to ~250 in/lb sometime soon.
    Alta PSRS front control arm bushings
    TSW X-brace
    Running a cheap 17x7" wheel (light and cheap) Kazera KZ-Vs (they were on sale)
    -2 front -1 rear camber, lowered about 1/2", 0 toe all around.
    Some 19mm rear bar on mid position.
    Springs are too stiff for the street, that's why I'll go back to the 250 lb/in springs. I'm pretty happy with the PSRS, but if I were to do it over, I'd go with Powerflex polys. The PSRS is nice, but mine needed the sleeves welded. Bit of a pain. I had the RDR (now Helix) adjustable camber plates, but they add a touch of ride hiegth. The X-Brace really stiffened the car up, but couples noise into the cabin. Still, I think it's a great part that is well worth it's cost. 0 toe makes it a bit twitchy, but that's not a big deal. With all the settings I'm getting really, really even tire wear. I live in hills and every day has some twisties.
    Without the camber plates, track days would ruin tires something awful. Some is my driving, but going to -2 up front really cured the problem, and practically doubled tire life (well over 20k a set now, up from the low teens). Tire life increases paid for the camber plates for sure. I paid for the RDRs, but got the Hotchkiss for free. Bought the Ledas used, and had them rebuilt last year for ~$400.
    Matt
  4. panaphobic
    panaphobic Club Coordinator
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    agranger, nice setup! Keeping it nice and simple!
    Dr Obnxs, sounds like you have a pretty good setup going for your MINI! Works well for what you want it to do!
    Keep the post coming!
  5. JCC
    JCC New Member
    Dec 15, 2009
    190
    Installation Manager
    Sachse, Texas
    Dibs on your TSW springs if they're not promised elsewhere and are not worn out when you upgrade to coilovers. :D
    My suspension is stock right now.
  6. agranger
    Jeremy... I'll try to remember to offer 'em to you first. Just start saving your pennies for the other bits. When you do these springs (especially the rear beta springs that are super low in the back), you will need adjustable lower control arms and I'd recommend doing fixed front camber plates as well if you can swing it up front... plus an alignment a week or so after things settle.
    I'd expect the springs to be fine. The struts however, after 60k miles on lowered springs and half a dozen weekends at the track will probably be shot. :D
  7. JCC
    JCC New Member
    Dec 15, 2009
    190
    Sachse, Texas
    Thanks! I'd definitely want to do the rear adjustable control arms and some sort of fixed camber plates. I'm still on OEM struts myself, but I haven't been to the track. At 80k miles, not sure how long they last.
  8. agranger
    They are gonna be pretty well shot by the time I get ready for the coil overs and the springs will be available. 80-100k is about the limit on stock struts with moderate use. I'm planning for the coil overs 'cause with the lowering springs and track days, mine will go sooner than usual.
  9. JCC
    JCC New Member
    Dec 15, 2009
    190
    Sachse, Texas
    Oh well. Keep me in mind anyway and we'll see. If the struts go out while I'm still under my aftermarket warranty, I may see if they'll give me money toward struts and I'll pay the difference for KW V1s myself. Wishful thinking.
