1st Gen R52 Cooper Convertible Where are the door airbag sensors located?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by TOPLESSMINI, Apr 19, 2016.
  1. TOPLESSMINI
    TOPLESSMINI Member
    Sep 1, 2015
    31
    11
    Software Consultant and Training Specialist
    Kingston, ON
    I have a Left Door Airbag Sensor fault. Just received my replacement part and ready to replace it but I can't find any info about it in my Haynes manual or online.
    Has anyone replaced one of these? Any tips would be appreciated.
    Cheers,
    M
  2. BlimeyCabrio
    There are a couple of side impact sensors. One is physically in the door, up high below the side view mirror. The other is just behind the shoulder belt winder.
    Figured Blimey would know. Probably knows more about convertible construction than most MINI techs.
  4. BlimeyCabrio
    I think that's a pretty safe bet. At least for R52s. I know R53s pretty well, too. :Thumbsup:
  5. TOPLESSMINI
    TOPLESSMINI Member
    Sep 1, 2015
    31
    11
    Kingston, ON
    Thanks Blimey. Gives me a place to start!
    Guess I better disconnect the battery before replacing the sensor. Just in case...
    I'll let you know how it goes.
    Cheers,
    M
  6. BlimeyCabrio
    YES always disconnect the battery when "playing" with the airbag system.
    If you remove the interior door panel and shine a light up in the front part of the door cavity, you should see the sensor up there.
  7. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    Suggest having a beer after disconnecting the battery to allow the vehicle airbag capacitors to discharge completely before tearing into things. :beer
  8. TOPLESSMINI
    TOPLESSMINI Member
    Sep 1, 2015
    31
    11
    Kingston, ON
    Always appreciate all the good advice on Motoring Alliance.
    Here's one to you! :beer
