Brakes Wheels 1st Gen Tires Who are the quality aftermarket wheel mfg's
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by TGS91, Oct 18, 2010.
  1. versus
    versus Active Member
    Sep 8, 2009
    553
    87
  2. Justa Jim
    Finding 15" in a 5 or 6 is not easy. Just ran across XXR Wheels. Any thoughts on these?
  3. Rally
    Rally New Member
    50
    Ohio
    Garbage. Used to be called Sportmaxx
    5 or 6 is definitely a skinny wheel which will make the search more difficult. Finding 15x7's would be a breeze.
  4. Justa Jim
    That is what I was afraid you were going to say. Yes, I am finding they are hard to locate and less weight then the 13 lb OEM is not happening either. :sad:
  5. Rally
    Rally New Member
    50
    Ohio
    Yah, the OEM 15's are pretty light, which is super nice.
    If you're not opposed to stepping up to 7" wide wheels, you could look into the 949 wheels. Only 11.9 pounds for the 15x7's.
    I personally love their look and they're available in some nice colors. A great performance/autox wheel.
    15x7 6UL Silver
  6. danf
    danf New Member
    Aug 30, 2009
    33
    How about 6ULs? I'd like to pick up a set in 15 x 8 eventually.
  7. Justa Jim
    Nice wheels, thanks. Maybe I'll get my OEM wheels painted or something.
  8. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    BBS RG-F in 15x7 weigh 10lbs.
  9. goaljnky
    3,105
    394
    And those are on sale right now directly from BBS:
    BBS "Fall Special" through November 30, 2010, $338 (per wheel)
    They also have RGRs in our fitment:
    BBS "Fall Special" through November 30, 2010, $528 (per wheel) Regular Price is $655 per wheel. The special price is for the Diamond Black finish only.
    Top of my list would be Volk (Rays Engineering) and Work.
    Anyone know enough about them to rate Enkei, Weds or Advan?
    Advan are made by Rays for Yokohama.
    Enkei is a darn fine midline wheel, not a BBS but also not a Sportmaxx.
    Weds used to be another decent midline wheel but that was years ago, I don't know what they are like now.
  12. Justa Jim
    I am learning that when you guys talk, it is in regard to what you all do most, which is tracking. I realize that a top of the line wheel is necessary for that, as it should be. I do not skimp in any way when buying the tack that keeps me on the top side of my horse. With that said I do not track, auto-X or the like. With that in mind what is a decent, light wheel?
  13. Rally
    Rally New Member
    50
    Ohio
    I never track my car and never plan to:prrr: I still think a quality wheel is important.
    I tried cheap wheels once (Flik) and will never do it again.:frown2:
    With that said, if you want light wheels you're going to have to go with track-oriented wheels. The only reason a company works hard to lighten a wheel is because they're making a performance wheel.
  14. Justa Jim
    Sorry Rally, I left out the "stance" group. You make a good point, skimping never pays off in the long run. :Thumbsup:
  15. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Dat's what I have slated for Augie. Not sure if in time for special as I have a couple things earmarked ahead of wheels
  16. Justa Jim
    PGT got my attention with the wheels at 10 pounds. The Price others quoted was scary, but I went to their site to check things out. Was impressed as it opened, but was unable to search for a certain size, found it user unfriendly and left after hearing the opening song three times. Is there a trick to making it work?
  17. andyroo
    andyroo New Member
    227
    6
    Columbia, MD
    A poor quality wheel will also be more likely to bend, which is more of a problem on the crappy roads I drive than some tracks.
    Light strong cheap, pick two. I chose decently light, decently strong, and fairly cheap Rials as wheels to tide me over until I get something nicer. Sort of a temporary middle ground.
    Light wheels are a nice improvement even on the street, but durability is important too.
  18. goaljnky
    3,105
    394
    Go to bbs-usa.com. Click contact link. Click on close outs and specials. Click on the wheel model. Call BBS at the number given.
  19. Rally
    Rally New Member
    50
    Ohio
    This is very true, and the point I was trying to make as well.
    The same can be said for the lower quality finish you find on cheap wheels. On my cheap set of wheels, the clearcoat was spidering within a year of ownership (and that was with regular, acid-free cleaning).
  20. PGT
    PGT Wheel Whore
    Leesburg VA
    if you're going to run a 15", be sure to run a stiff tire. With ALL that sidewall, you're going to want some steering feel left. I made the mistake of running Kumho Ecsta SPT and though the ride was like a Caddy, I felt the "fun" noticeably diminished.
