Brakes Wheels 1st Gen Tires Who are the quality aftermarket wheel mfg's
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by TGS91, Oct 18, 2010.
  1. JCC
    JCC New Member
    Dec 15, 2009
    190
    Installation Manager
    Sachse, Texas
    What about the Tenzo R Type M Version 2 in 17x7 or the brand in general as far as how well built, etc.?
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Tuner wheels, middling quality, from what I've seen
  3. JCC
    JCC New Member
    Dec 15, 2009
    190
    Sachse, Texas
    Thanks.
  4. Justa Jim
    Where does the term "Tuner" wheels come form? I see different makes called that.
  5. Rally
    Rally New Member
    50
    Ohio
    Tuner, is usually short for import tuner. It's a "scene" or car community. Tuner is kinda like the pep-boys, fast&furious style. Big spoilers, lambo doors, cheap wheels, etc.
  6. goaljnky
    3,105
    394
    So tuner is actually not so much?
  7. Rally
    Rally New Member
    50
    Ohio
    I'm assuming youre referencing engine tuning? The quality "tuner" cars have a great deal of engine work done and usually run standalone management systems that require tuning.
  8. Justa Jim
    Got ya. Thanks. :Thumbsup:
  9. goaljnky
    3,105
    394
    Take it easy. Just going by what you posted:
  10. Rally
    Rally New Member
    50
    Ohio
    Sorry if it came off otherwise...I was simply rephrasing myself since I left that portion out in the original description.
  11. Justa Jim
    Koing, Daylite, 11.8 pounds, 15X6.5, black w/yellow stripe. :Thumbsup:
  12. old81
    Those will work well on your MINI. :D :beer
    When will they be on the MINI, pictures.... Please!
  13. Justa Jim
    Well, I have to get additional information first. The site is not informative, but it seems they may be for the first generation only. If spacers will work, then that is fine, but I have to find out if that is the case. I like them, so I hope they will work out. I'll keep ya posted.
  14. Rjgross
    Rjgross New Member
    Colorado Springs
    Has anyone ever used Drag Extreme Alloy wheels. I am looking at 17x7 DR-19 (GLOSS BLACK, GUN METAL, CHROME, SILVER).
    Has anyone used them? Have they had any problems? Are they a good quality wheel?
    Thanks
  15. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Decent for DD. Not high quality and not light weight though. They are a cheapie brand (Carried by Discount Tire). The DR-19s look good though.
    BTW, I am running Kyowa 206s on my MINI for track days. Nice 17x7 rim at 17lbs.
    ...And no. I'm not using that rubber on the track. It's just what came on them when I bought them.
  16. Rjgross
    Rjgross New Member
    Colorado Springs
    thanks for the info. I don't run on the track so I think the DR-19 will be find. Of course no I like the Kyowa 206s. So many choices.
  17. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Weight is certainly a issue
    What I think the issue when you take track use out of it is wearabilty
    The lower cost tuner wheels, which I own a set, do not wear as well as the higher end
    They scratch easier, hold onto road schmutz easier, etc
    You do get what you pay for
    Finding a good wheel refinisher in your town and budget to take them to him once a year or so you should be in pretty good shape. Depends on how anal you are about your wheels
    Good luck, all the choices are NUTTY :eek:
  18. Justa Jim
    FYI, I saw some that were called "gun metal" and it is actually brown. I was expecting gray or blueish.
  19. Redbeard
    1,636
    398
    I hadn't heard of Kyowa until recently. Decent rims for tracking though. They are mostly lightwieght mono-block rims (despite my two tone wheels they are monoblock). They normally aren't cheap, they arent BBS/OZ/Enkei expensive either. They typically run the $175 to $250 per wheel range.
    www.kyowadesigns.com
    I got mine used for a helluva deal off of Terry from FUbrication. Otherwise, I couldn't afford them.
  20. Justa Jim
    Aren't there too many lug bolt holes for a MINI or do they line up so you don't use all of them?
