Winter to do list(s)
Discussion in 'MINI' started by Mr. Jim, Feb 9, 2011.
  1. Mr. Jim
    So we have the "winter driving or not" thread and what about all of us that have the MINI away now. Projects, repairs, etc?
    I'll start and once I really start i'll post in correct sections :D
    1. front and rear brake pads, rotors, SS lines,fluid flush.
    2. Install Vorsc. adjustable camber plates
    3. Install Mynes V2 header
    4. Install AFR gauge with sensor
    5. strip and refinish M7 hood scoop
    there might be more but that's enough for now.
    Anyone else?
    Cheers
    Mr. Jim
  2. Minidave
    4,595
    In another 1500 miles or so I'll
    1) Change oil and filter
    2) Rotate and balance tires
    3) Clean the winter scum off, both inside and out
    4) polish and wax
  3. BThayer23
    Already done:
    replace crank pulley
    rebuild front calipers
    clean wheel hubs with dremel and swap plastic centering rings for aluminum with fresh anti-seize
    regrease rear caliper slide pins
    install new front rotor discs & new rear rotors, inspect hat and hardware
    new front/rear street pads, bed in
    install cravenspeed shifter plate
    Still on the list:
    Re-install front brake ducts, repair ducts with duct tape as necessary
    Flush brakes with new fluid
    Bleed clutch slave with new fluid
    Install new quickfit pro harnesses
    Wash and wax car
    Clean up paint chips on hood and front bumper
    And that doesn't include my daily driver, which is leaking oil as we speak!
  4. Justa Jim
    Why did you wait so long? I's almost March. :D
    I've done nothing to mine other than load a bunch more miles on. Can't wait to clean all the carp off the MINI & take the snow shoes off. Come on SPRING!!!
  6. Justa Jim
    Same here and I don't have snow shoes on.
  7. Mr. Jim
    Well, I've been assembling all the parts needed so I could just hit it all at once, plus it's been too cold to get motivated! :)
  8. Justa Jim
    Let me see if I have this right. You store you car during the winter, so you can do mods on it, but because it is too cold you wait till spring to start them? Then your car is back on the road by summer, just before it goes back into storage for next winter. Hummmmmmm...... :cornut:
  9. Mr. Jim
    Hey, it's not spring yet! :) it will be done before driving season starts this year. And for the record this winter has been way colder and the mod list is longer than previous years. There is a method to my madness :)
  10. Justa Jim
    OK, I have to ask. When you finely drive it out of the storage bay, if you see it's shadow, do you go back inside? :lol:
  11. Mr. Jim
    No way, that would mean the sun is out, wouldn't it? Now if I didn't see it's shadow, lol that would be a different story :) But seriously once the salt is gone from the roads the MINI stays outside until the winters first road salting.
  12. Justa Jim
    Just messing with ya. Hibernation can be a good thing. :D
    :sleep::sleep::sleep:
  14. Mr. Jim
    :Thumbsup:
  15. Mr. Jim
    Back in the saddle again!
    All the winter projects are complete and just came back from alignment shop and all I can say is SWEET! And with two days till spring no less. I told you there was a method to my madness :D
  16. Justa Jim
    So, if you store your MINI for the winter you have to have it re-aligned? Man, I'm saving money by driving mine. :cornut:
  17. Mr. Jim
    Now Jim, do I have to explain everything to you :crazy:
  18. Justa Jim
    :cool:
