Brakes Wheels 1st Gen Tires Winter wheels on. Shimmy in steering wheel
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by 05r50, Jan 6, 2011.
  1. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    Problem Solved
    Well,
    Chuck gave me his professional opinion Sat. at Breakfast that yep something is not right with these tires:D
    TireRack sent me replacement hub center rings just in case. So, I finally decided to pull a wheel and check the original ring to the replacement. Sure enough, the original ring has a larger inside diameter than the replacement. :mad2:
    I would guess that the gap was at least as thick as a business card or maybe several cards.
    So, I put the new rings on all around, nice and snug, and no more vibration.:beer
    Thanks everybody for the help.
    I wish the dealer would have at least checked this out for me. ( I did ask them to check the rings). Well I guess that is a discussion for me to have with them.
    Jeff I'm sorry you had to go through the mill trying to find the vibration. I'm glad that it was actually something easy to fix.:Thumbsup: You might want to remind Alex of all of your troubles when you buy your next set of tires. Think Discount!
    Bet you loved those snow shoes today....
