1st Gen R53 Cooper S Wipers PIAA super silicones.....
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by west7, Dec 14, 2013.
  1. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I'm using PIAA blades but I don't remember if I put an 18 or 19" blade on my passenger side. However, it does conform to the windshield perfectly. I'm using the standard super-silicone blades.
  2. AAONMS
    AAONMS Well-Known Member
    5,027
    221
    I play with trains...
    Fruit Cove, FL
  3. Angib
    Maybe. But I'm old enough to remember when concentrated air jets were going to bring about the end of the windshield wiper.
    It's all brought to you by the same folks that made the jetpack the everyday household device it is today.....
  4. TheModFather
    Wasn't Honda playing with the air jets about 10 years ago?
    Neat concept, but too much to go wrong.
  5. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    I've been selling and using PIAA blades for years. I really like them and have had great luck with them, haven't seen any that didn't fit the glass.
    BUT if you have a new 2013 MINI, including a GP the PIAA blades will not fit the arms. real bummer if you ask me.
  7. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    Do you PIAA users use additional product such as rainx or aquapel? Also, any need for the spoiler on the sporzas or the super silicones do the job just fine?
  8. Dave.0
    Yup, I used Rain-X after every detail. (Monthly) :crazy::ihih::lol:
  9. ScottinBend
    AquaPel once a year.
  10. silky
    silky New Member
    Oct 12, 2009
    1,086
    51
    A pair of super silicones are awesome indeed but not my preference...
  11. beken
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I use Rain-X....sometimes.
  12. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    I've been using rainx on mine because i clean it pretty often. That being said, I've seen some rainx washer fluid. Have you guys used it or do you use factory washer fluid, or something else altogether?
  13. ScottinBend
    I just use the 20/10 concentrate and mix up my own low mix formula. I don't like the idea of spreading the RainX washer stuff all over the car.
    I use the RainX washer fluid & yes I believe it does help.
  15. ZippyNH
    The rain-x washer fluid is a bit different...same for the "add to any washer fluid" stuff...
    It does seem to help...but it tends to leave a haze everywhere... Very short lived too..seems to be a very soft polymer of some type...almost like a no rub wax......meaning a spray is good for a bit...but not the weeks like from the rain-x in the bottle you spray and polish with a rag....works in a pinch...but the haze where it flows back and leaves more spots than most other washer spray is an issue for some.
  16. Dave.0
    Rain-X on glass and only plain jane blue washer fluid for me.
  17. BlimeyCabrio
    I just installed first set of Michelin Stealth blades to try, haven't used them in the rain yet.
    They're a hybrid of a beam blade and jointed metal blade so they're supposed to fit the windshield better at all angles, have a fairing so they look pretty. We'll see how they work.
    FWIW - I always run a 17" blade on the passenger side, instead of the recommended 19".
    Solves the "not fitting the curve of the windshield" issue with almost all blades, and has minimal impact on swept area.
