WMW has TSW X Braces back in Stock
Discussion in 'Sponsor Messages' started by Way Motor Works, Sep 2, 2014.
  1. Way Motor Works
    Way Motor Works New Member
    205
    MINI Tuner
    Atlanta
    Way Motor Works just got a new batch of the famous TSW X Braces for the R55 R56 R57 R58 R59 R60 R61 MINI. If you're wanting to reduce the body flex and make your MINI stiffer the X brace is by far the best solution. Designed years ago by the TSW company, the X design has proven to be the superior. Plus it is the simplest as no drilling or cutting is required to install. The X brace uses 4 existing mounting bolts to make install take less than 5 minutes.
