Way Motor Works is clearing out our WMW Stainless Steel Brake Lines for the end of the year. We have Brake lines for all MINIs. If you have looked at many options of brake lines you'll notice they all look the same. But that isn't true. The one thing that sits ours apart is that ours are direct fit and we do that using the fittings machined to the exact same design as the original MINI brake line ends. You'll see ours have the same little star shape to lock them into the mounts on the body, many others are a loose fit or require you to grind on the body mounts. Order yours today. R50 R52 R53 WMW Brake Lines R55 R56 R57 R58 R59 WMW Brake Lines R60 R61 WMW Brake Lines
