2nd Gen R56 Cooper S Yet another concern...a little more serious this time
Discussion in '2nd Generation: 2007+ R55 through R61' started by tmancoopers, Oct 2, 2013.
  1. tmancoopers
    tmancoopers New Member
    Sep 21, 2013
    21
    OKAY
    so get this, all day today the car ran fine. leaving my friends place i go to start the car and....nothing. no crank, nada. however, all the lights turn on, all the acc. turn on, the dash even indicated that the ignition is on but the door is open therefore to my understanding, the key...or better yet the fob...is being detected. however the car wont start. obviously being a bunch of 20 some year old guys we push start it and off i was. after getting home, i decided to re-start the car to see if it worked and obviously...it didnt start. any ideas? i read a couple places that the clutch sensor could have fallen but i checked and theres nothing that had fallen. im thinking maybe the starter but i feel as if that would have been a little more gradual rather that start now but not later. i tested the battery and read a 12.5V. so battery isnt dead.
    any ideas??
  2. Justa Jim
    I'm not sure what is wrong with you car, but if you hit the "shift" once in awhile you could could fix you typing.
  3. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    year and model? S? Justa?
  4. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    ^^He did hit shift....the first 4 letters lol
  5. nxtMINI
    nxtMINI Active Member
    Apr 26, 2010
    405
    40
    Michigan
    Yeah need more info.. What year? Is it a Cooper or Cooper s? Did you buy it new or used?
  6. Nathan
    According to the Garage the owner has created this is a 2007 MINI Cooper S
  7. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Could be the starter. They rarely give any warning when they are going. If you can't get it to start and all your electronics come on, that's probably the culprit. Take a small hammer and give the starter a few taps. Not too hard or you could crack the casing and then you are just screwed. That will get you by for a little bit untill the starter completly fails. I would suggest pulling the starter and taking it to Autozone, Advance Auto, ect and have them test it.
    Check all the connections from the battery to the starter including the grounds.
  9. tmancoopers
    Sep 21, 2013
    21
    I didn't realize I joined the mini cooper smart a** forum. But thanks for the useless input.
  10. tmancoopers
    Sep 21, 2013
    21
    Yep it was the stater
    ouch, how much is a starter for one of these cars? glad you got it going again.
    lots of good help here & lots of smart arses, that's what makes this such a great place to be. :yesnod:
  12. Justa Jim
    Sorry, Welcome to M/A. :Thumbsup:
  13. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Looks like about $340 for a reman from eminiparts, great guys by the way.
    2007 Mini Cooper Parts -
    I wouldn't let it go for very long before finding one.
  14. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Glad you found the problem.
  15. Firebro17
    Hmmm. Hang out a bit, it gets better. Glad you found the problem.
