Your Top Speed in a MINI
Discussion in 'MINI' started by Nathan, Jul 15, 2010.
  1. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Now this is were having dyno data based on a chassis dyno helps to resolve some performance tuning(not necessarily ECU) questions. A look at the TQ/WHP curve might shed some light?
    As you are mentioning total HP/WHP has a key factor in achieving total MPH. Torque is the value to support by calculating actual hp to overcome natural factors hindering speeds above 150 mph.
  2. track-toy
    track-toy MINI of the Month
    Test Driver
    Pittsburgh, PA
    Sorry Crashton,
    Been away for a while. I agree with your comments about Nelson Ledges. I've found a line around the carousel that works for me and I absolutely own turn 13 (truly MINI territory). Traffic down the back straight is a challenge as you said. The brakers at the kink are a real problem but you have to allow for lesser performing cars handling-wise. On slicks, I am just not going to lift for a mere kink unless someone parks a regular car in my way (use Mustang, Charger, Camero, Viper pretty much interchangeably in this context). BMW M3/M5 is a different story but not by too much.
  3. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    My car turned 147 mph on the 405S in Irvine California a year or two ago on only 225 whp
    I don't remember what gear or rpm i was in but it was on gps. and still slowly pulling.
    Now that i make a lot closer to 270 i'm sure i can go a bit more. Then again I'm truly afraid of what will happen if i get caught.
    I was pulled over here positive i was doing about 55-60 and was ticketed for 78 in a 45. I don't trust the police.
    Its pretty interesting to see just how fast the mini is capible of.
  4. Rooster
    Rooster New Member
    May 22, 2009
    Systems Engineer
    West Hollywood, CA
    Then maybe you should take it to the track?
    I'm not sure there is a track with a long enough straight to hit 147 in your MINI. Maybe the Bonneville salt flats. :Thumbsup:
    I wish you no ill will, but if you get caught they are going to throw away the key. ;)
  6. ColinGreene
    438
    293
    Orange county Ca
    Pft you take it to the track joe, No ones perfect. :devil:
    I only did it that once or twice, I'm over it.
